That's a curious symptom with the window lift.
I found out that power cuts like battery replacements and in my case disconnecting the door harness will facilitate the need to reset the auto lift feature.
All you have to do is turn on ignition to accessories, roll the window down a bit and then hold the button to have it lift until its fully lifted and still hold button for a few seconds to apply the fix. Now the auto up and auto down feature works again
