Old 01-15-2015, 01:34 PM   #4 (permalink)
ennored
I assume you are using a BSFC number to go from MPG to HP? You mentioned some numbers in your other thread that makes me think that. What are you using for the MPG (and/or fuel flow)? Just the truck's data via the OBDII port?
Are you using a single number for BSFC? Or do you have a map?
It's a useful way to think about the numbers no matter how you did it. Really shows what the aero is worth.
