Old 01-15-2015, 02:04 PM   #119 (permalink)
dirtydave
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
First I took a POS electric screwdriver I found at work.
here is a link to one on ebay Cordless Screwdriver 3 6 Volt Ni CAD Adjustable | eBay
This thing is powered by 3 Ni-Cad AA batteries. And has enough torque to spin in a circle and that's about it. Horrible as an actual screwdriver.
Anyway
Went outside and measured the desired grill opening. 3" X 11" should be plenty for this car. If not It will be easy to make larger this summer.
I took it apart, sniped the wires that go from the switch to the motor,
Strip'ed em, got a super long strand of speaker wire (15' - 18').
Added the new wire Taped it all up. Put the other guts in a plastic box.
Add tape. Left a spot without tape to see the charging LED. I put the motor in a plastic bag to help waterproof it. Found a old metal coat hanger and duct taped it to the part that spins on the motor.
(wish I had zipties would work better.) Cut a piece of coroplast 3" X 11" put the coat hanger in the grooves.
I'm going to let it charge a while. after it is on the car I will need an extension cord to charge it. I figured it will last a while on a charge because I am only going to spin it once or twice a day.
Went out to the car and realized that I had to cut the motor off the box to fish it up and around to the inside of the car. and add about 3' more wire.
Works like a charm! I need some zipties and some masking tape to put on the edges around the piece of coroplast to fill the gaps. Ugly but works fine! Fits good on the dash wedged under the small useless solar panel.
Keep it ghetto yall!
