Old 01-15-2015, 05:43 PM   #1602 (permalink)
cts_casemod
Right, lets stick with that then.
Originally Posted by P-hack View Post
I do like the boost topology best (short of rewind), it beats on the source the least and allows a direct path to the motor when all those volts aren't needed.
Buck works just as well. The inverter is buck by default.
With a mirrored supply, the ground is floating when the converter is operating. When not, a reverse diode across the capacitor completes the path. The output will be Vbat - 0.7, just like in a boost converter.
In case of a failure on the power switch, the input gets shorted to the output trough the inductor rather than shorting the supply.
Ignore the 3 IGBT's idea. Just me thinking out load.
