Originally Posted by cts_casemod
In case of a failure on the power switch, the input gets shorted to the output trough the inductor rather than shorting the supply.
This is what I know as an inverting buck boost (not a buck):
So what happens to the output when the switch gets shorted? zero volts you say?
