Old 01-15-2015, 06:44 PM   #12 (permalink)
Cobb
I got new 10mm wider tires, but no diff. Now on the old ones I notice the right side wanted to hydroplane. I checked and the tread was more worn than the drivers side.
Now wider rims spreads the tire out more, if they are fully inflated to sidewall psi the tire may not of had the same contact with the road. There is a limit to tire vs rim width and how you mix and match them.
