Old 01-16-2015, 05:17 AM   #2 (permalink)
MobilOne
With no accelerator pump or one that does not work, the engine will stumble or stall when you try to accelerate. When you give the engine more throttle in order to accelerate, the mixture will lean out causing the engine to stumble. The accelerator pump gives a shot of gas at this time so the engine accelerates and does not stumble.
