Old 01-16-2015, 11:29 AM   #7 (permalink)
Ironside
I've owned both versions in the past and I remember reading somewhere that the 400A has a smaller diameter bore carb in order to improve the fuel consumption, should be easy to check. If this is the case you may need or want to use the matching manifolds.
Just checked the Haynes manual CB 400T - VB31A (32 mm)
CB 400A - VB24A (28 mm)
