Thats a buck boost converter as described on the document I posted on #1599. The second diode is replaced by an active switch.
The output is a negative voltage with amplitude from 0 to -Viin, which can be used to sum with with the input.
Are you saying Texas instruments is using the wrong terminologies!?
