Old 01-16-2015, 02:55 PM   #1 (permalink)
ToddT58
Alternative Fuels Addict
Building a 4.9 for E85 and/or woodgas
I want to build up a Ford 300 six-cylinder to run on E85 and/or woodgas. Both fuels call for increased compression and advanced timing to optimize performance. A race shop will do the machine work and then guide me in the rebuilding process. But... what hardware should I use?
The vehicle is a '95 F-150. Rather than try to adapt the OBD-1 system, I'm thinking about the Megasquirt fuel injection route.
What are some pistons available to get max compression? Unlike a Chevy 350 or Ford 302, the aftermarket doesn't have much to offer for the Ford 300. Some have said pistons out of a 400 will work.
Any thoughts on cam profiles? Suggestions for building a non-flex fuel engine optimized for alternative fuels? I have been an efficiency nut for years and these days, I really like domestic fuels that I can make, hence alcohol and wood.
