Old 01-16-2015, 09:23 PM   #22 (permalink)
Striker2237
Silver Magnum - '03 Dodge Ram 1500 Laramie
90 day: 11.43 mpg (US)
Originally Posted by spacemanspif View Post
How about converting the V8 to 2wheel, rear drive and take advantage of the off-set yolk on the front axle to run a rear drive 4cyl backward for 2 wheel, front drive. Best I can think, this is the simplest way of doing things but would require major modifications to the truck bed and rear frame to make room and support for the all new power train. Maybe come up with a way for both engines to use the same radiator/share coolant so that you can cut down on "extra" hardware.
This unfortunately won't work (was my original idea but a few things killed it) because my rear axle would need to be decuopled from the main trans or the small engine would have to also turn it (allot even when it is in neutral) and because the rear axle is a LSD it would quickly destroy itself if not powered
