01-17-2015, 06:23 AM
#31 (permalink)
Originally Posted by Striker2237
Tag axle?
A tag axle is typically found on a semi tractor. It is the axle behind the drive axle and is usually able to be elevated from making contact with the roadway when not needed. It can also be found on semi trailers. These are also able to be lifted when not in use. This allows the tires to avoid unnecessary wear and also saves fuel. The axle is lowered when it becomes necessary to help spread the vehicle's weight over a greater area. It is also possible to find a tag axle on farm equipment, as well as certain heavy construction machinery.
What Is a Tag Axle? (with picture)
Originally Posted by RedDevil
Google is your friend.
http://ecomodder.com/forum/showthrea...tml#post385527
