Have you made any attempt to get the 6.7L diesel engine that is already in it running as efficiently as possible?
Go through it with a tuner and saws all and cut out all the garbage you don't need like the DPF and EGR cooler and reprogram it to function like an actual diesel powered truck instead of a fuel oil powered emissions scrubber plant.
