Originally Posted by dirtydave
are you neutral coasting in your auto?
No. The black magic slushbox weirds me out a bit so I leave it in gear for coasts. At higher speeds, I presume when the tc is locked, the engine rpm coincides with the vehicle speed; but when I coast at lower speeds the rpm drops to idle, around 550rpm.
Boy I sure miss having a standard trans.
