Old 01-18-2015, 12:29 PM   #70 (permalink)
brett701
Summary
Originally Posted by synergy View Post
I like that prius. Its similar to the insight. You get better gas mileage in the pruis I say check it out. I just didnt suggest a prius due to your looks criteria and the fact that their resale value holds relatively well compared to the insight which was sold for much less new.
And a Kill switch would be more work than worth. Youd get better gains in other areas. Roof rack delete on the Vibe would help alot. Along with just pumping up the tires and driving for mileage. Your right foot has the most to do with your mpgs at the end of the day.
HERE IS THE SUMMARY.
I Tried to clean it up for you.
I've contacted everyone.
CAR A
Honda Insight Hybrid EX Civic 2010
I'd like to get the price down on this to $7500
6365798240
https://plus.google.com/u/0/10240334...45103451714828
CAR B $4995 from Breckenridge Motors
2004 Pontiac Vibe GT 4dr Wagon
Top choice at the moment. Hopefully can get for $4,200.
The main concerns:
What is the tire condition, newer breaks on the car?, when was the cat converter changed? Will I need a timing belt change & has it been changed?
(314) 690-2962
CAR C $3199
2004 Pontiac Vibe
Has new tires & new cat converter.
618-650-9040 must call her.
CAR D $3350
2005 Pontiac Vibe
Tires look warn.
660-827-4339 or 660-826-1434
CAR E $4000
2007 Pontiac vibe
This is a curious price. She took this car in on a trade and did repairs to it. She is looking to trade again.
She put new tires, new front brakes,new cat converter, new wipers.
It needs windshield.(That's reason it is $4000)
CAR F $4500
REDUCED ! 2009 Pontiac Vibes
2009. Seems like too good of a price.
The car has been regularly serviced, oil changes,air filter,tires rotated, rear brakes new rotors 7000 miles ago, new battery 3 months ago, alternator last year, transmission flushed 4000 miles ago. I have taken good care of the car. The only thing that doesn't work is the horn ( it started sounding funny then quit, so I'm sure it just needs a new horn) but There are no other issues or pending problems with the car. It is tight and drives down the road very good. It has the same motor and body as the Toyota Matrix so parts are readily available for the entire car. If you have any other question give me a call (217) 821-7308 (Effingham,IL)
CAR G $3400
2005 Pontiac Vibe aka Toyota Matrix - Sunroof - Automatic
some hail damage & paint fade
Brand new brakes
Don't know about the cat
Tires are only 5 months old
Don't know about timing belt
5 minutes from my house.
