Old 01-18-2015, 09:54 PM   #2 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
I think you will hit a bump or turn hard and the sidewall will flex enough to rub and grab the tire at speed. I think you are talking about mounting them to the spindle and then cutting out a bottom chunk for the contact patch of the tire. The 1969 Plymouth Roadrunner had some promo discs that worked that way just covering the wheel and none of the tire. I don't think this would work on a car w/o a stationary spindle but there are some spinner type wheels that use bearings to create a stationary center piece rather then the normal spinning center piece. here is the Roadrunner in action
The Following 3 Users Say Thank You to Hersbird For This Useful Post:
aerohead (01-20-2015), Cd (01-20-2015), Xusn96 (01-21-2015)
