All tires bulge with heat. You'll also have to mount that thing on there really well (x4) then you have issues with checking your pressure and making sure there are no general problems with the tire.
If you can make this work, I'd highly suggest weekly removal for inspection which is something you should keep in mind while figuring out a mounting situation.
