Old 01-19-2015, 04:48 PM   #8 (permalink)
spacemanspif
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Sounds like dragging brakes. Check the calipers and maybe pull the slide pins and re lube them to make sure the calipers are floating freely. Saturnfans recommends syl-Glyde from NAPA as it won't cause the slide pin boots to swell and reduce pin float. Those cars like to have pins bend a little too and make the calipers go cock-eyed so check pad wear as well.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
