Old 01-22-2015, 08:44 PM   #20 (permalink)
betasniper
betasniper's Avatar
Red - '01 Honda Insight CVT
Gen-1 Insights
House of Tudor
90 day: 59.17 mpg (US)
Civic Hybrid - '12 Honda Civic Hybrid
Bahamut - '18 Chevrolet Volt LT
Team Volt
Plug-in Hybrids
In my opinion, 2/3 throttle is far to much throttle because that would almost always put you at atmospheric pressure. I have a vacuum gauge in the wagon and barely 1/4 throttle (estimated) would cause the vacuum reading to be 5"vac at low rpms and anything past 1/3 (estimated) results in 0"vac. The MAP is not linear with throttle position.
Edit: It would be interesting if you have a SG or UG to see both TPS and MAP on the same screen to see what the correlation is.
: Brothers
: Dad's
