Old 07-22-2008, 02:29 PM   #4 (permalink)
lovemysan
lovemysan's Avatar
gutless wonder - '02 Saturn sl sohc
90 day: 40.17 mpg (US)
econoburban - '05 chevy surburban 2wd LT
90 day: 19.43 mpg (US)
Is this a manual trans. If so does the manual spec a GL4 rated fluid? I find it a real common issue that mechanics will put a GL-5 trans oil in a GL 4 rated unit. The problem is that GL-5 fluid will corrode yellow metals. Often synchronizers are made of yellow metals. It sounds just like what happened to inlaws nissan pickup. Changed fluid and in a few months 2nd gear started to grind even shifted slowly.
I've used redline mt90 (spec'd replacement for 75/90 gear oil) for my nissan, it will improve the shift quality. You can call redline's tech and get them to recommend which of there fluids to use.
2002 Saturn SL
sohc + 5spd = 50mpg
mod pics see link below
http://s75.photobucket.com/albums/i3...emysan/saturn/
Real men have wheel skirts.
