Originally Posted by renault_megane_dci
How good are you at P&G ?
After all, it's just a matter of finding the sweet spot speed wise ...
I've started using P&G a lot when driving in town but at speeds above 50 MPH my car slows down very quickly.
Town runs are usually short most of the time (3-5 miles each way) so the engine is far from reaching its optimum efficiency.
What speeds do you P&G between? And do you use the technique only when on flat ground?
