UG reads like I don't have DFCO, and some other UG questions
I just set up an UG in the Corolla last Monday, and when I am coasting in gear (which I avoid as much as possible), the UG reports MPG readings in the hundreds, but not the 999.9 MPG that I would expect to see. This has been the case all the way from 3k to 1.1k RPM, so it's not like DFCO is just kicking in at certain RPM ranges. Any idea what's going on? The Corolla should have DFCO...right?
Also, sometimes when I turn the key into accessory when pulling into a parking spot, the UG will read 999.9 MPG; other times, it read 00.0 MPG. I can't figure out what is causing the different readings.
