Old 01-24-2015, 11:32 PM   #265 (permalink)
P-hack
P-hack's Avatar
awesomer - '04 Toyota prius
If you are targeting acceleration bsfc, then you just do one run per map/load row, you decide how accurate and repeatable you want to be, just document the procedure a bit. The horizontal part should have lots of data points automatically.
After that you can do some steady state sanity tests north/south/east/west of peak acceleration bsfc. It should be a binary search if you are looking for peak (which is relatively few runs).
