Thread
T-100 belly pan...
01-25-2015, 03:06 PM
18
permalink
BamZipPow
T-100 Road Warrior
BZP T-100 (2010)
- '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3:
24
mpg (US)
BZP T-100 (2011)
Last 3:
23.66
mpg (US)
BZP T-100 (2009)
Last 3:
19.01
mpg (US)
BZP T-100 (2012)
Last 3:
25.45
mpg (US)
BZP T-100 (2013)
- '98 Toyota T-100 SR5
Last 3:
25.79
mpg (US)
BZP T-100 (2014)
Last 3:
23.18
mpg (US)
BZP T-100 (2015)
Last 3:
23.85
mpg (US)
BZP T-100 (2016)
Last 3:
17.62
mpg (US)
BZP T-100 (2017)
90 day:
20.78
mpg (US)
BZP T-100 (2018)
90 day:
20.19
mpg (US)
BZP T-100 (2019)
BZP T-100 (2020)
2012 Scion iQ
- '12 Scion iQ Base
Been dealing with some popping and cracking noises that seemed to come from the front of the truck. I had to pull the diffuser out since my hitch receiver had broken the welds off of the receiver reinforcement and git that re-welded back on.
In the process I discovered that the 2x4 metal studs I used fer building the diffuser with had cracked from the frame flexing. Lucky fer me, it wasn't catastrophic! With the diffuser removed, the popping/cracking noises disappeared!
I ended up replacing those studs with some 2x4 wood studs and extended the length to include the extended diffuser. The trailer bottom gap cover will still be attached to the rear diffuser without any issues. I did add extra hinges to allow the diffuser more articulation when the rear axle goes up and down.
Broken studs...
New wood studs...
New hinges to allow fer more articulation...
Dark Aero-The world's first aerodynamic single wheel boat tail!
12:25 PM
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead
(01-26-2015)
BamZipPow
View Public Profile
Send a private message to BamZipPow
Find More Posts by BamZipPow
