Old 01-25-2015, 11:22 PM   #22 (permalink)
redpoint5
90 day: 38.47 mpg (US)
Originally Posted by mcrews View Post
Just to be clear....they were going to charge $257 just for the belt... How much more for the labor??????
And you paid $18 for the belt and clicked your little Dorothy slippers three times and the belt was on.....right????
Or just maybe.....the truth is their quote included a couple of hours of labor and it took you all day????
Most accessory belts can be changed in 10 minutes. They are held on either by spring tension applied at one of the pulleys, which requires a pry bar (screwdriver) to move the pulley enough to remove/replace the belt. Other tension systems involve loosening 1 bolt to allow slack to be made on a pulley, and then removing/replacing the belt, and re-tightening the slack and bolt.
None of this is rocket surgery, unless perhaps it's a VW we're working on.
... and rear brake drums don't need cleaning. They get dirty and rust, and nobody cares.
I can perform most car service in less than the billable "book" hours that the shop charges, and I'm a novice with a very modest amount of tools. Imagine how quickly the "pros" with lifts and proper tools complete the 8 book hours of work they charged you.
The only 2 things I've allowed pros to work on so far have been tire replacement and oil changes. The lube shops are breaking even on the $20 oil change, fluid fill, tire check, and vacuum because I don't opt to replace my PCV valve, air filter, and wiper blades while I'm there.
