The PGM-F1 main relay ground controls the fuel injectors, fuel pump, o2 sensors, alternator, vehicle speed sensor, and maybe the PCM, one or more of which must be causing the drain.
I've not found a fuel injector fuse, so I'm going to splice into the
fuel injector wire, before it gets to the PGM-F1 main relay.
