Wow that does look nice!! No problem on the help, it was a blast! Just remember to watch those temps, you can go from good mpg to needing a new engine really quickly! May I recommend an aftermarket temp gauge? It's what I did on my '95 Camry and it worked great until the gauge broke.
[Edit]: I'll warn you, a ticket for not having a front license plate is 250$. You can cut the license plate thin and bolt it to the grill block so it won't effect aero, and you won't have to risk a ticket.
Do you mind posting behind shots of how you mounted the grill block? I have been thinking of doing something similar to my insight.
