You'd be better off with an econobox 5 speed and good technique. The plug in prius 4.4kwh battery is only good for 11 epa miles, and it is well engineered. I don't think your commute is a good fit for a budget "ev", and you will get crummy hybrid efficiency if you don't know exactly what you are doing.
