Scangauge not turning on
Ok for the short story: if I start my car and idle it for a seconds my scangauge comes on and everything is fine. If I get in, buckle up, release e-brake, clutch in and select 1st and THEN start the car and get moving rite away, the scangauge won't turn on....ever, unless I hit a button on it (usually the one with the red ring). This ever happen to anyone? Gauge is older unit with EM.com software update. I'm set on hybrid mode and think turn off if set to comp, thinking maybe I should change something but not sure what...
Thanks,
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
