Old 01-29-2015, 03:16 AM   #22 (permalink)
j12piprius
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
fuel injector wire kill switch
I removed the pgm-f1 kill switch yesterday, hooked it up to the main injector wire today, and it works! I've not gone for a test drive yet, but turned the switch off and on 10 times, with 3 second delays, and there was a negligible change in the voltage. Success!
Hopefully this will raise the break even point enough, that EoffC can be useful on trips. However, I think the aerodynamics will have to improve quite a bit, for that to happen.
The Following User Says Thank You to j12piprius For This Useful Post:
PaleMelanesian (01-29-2015)
