Old 01-29-2015, 03:41 AM   #4 (permalink)
Astro
Dreamer
Maybe try looping the rx to the tx on the usb to serial converter so that what you send from hyperterminal goes out through the usb to serial converter then loops back in. That way you should be able to see if the converter is happy and test it in various locations. Put something like the qbf phrase (The quick brown fox jumped over the lazy dog's back.) in a function key to enable easy sending and checking of the data.
