Old 07-22-2008, 07:52 PM   #9 (permalink)
ATaylorRacing
38 time NHRA/IHRA Champ
ATaylorRacing's Avatar
To gain more power out of the first car I drag raced I made a electric water pump set up. The car was a 81 Horizon and I bought an electric water pump called a "Water Guppy" that was used to circulate water in bass fishing boats. I had the water pump off of my car (due to bad leaks) and found that the thermostat housing had two bolts that lined up with two where the pump was. I simply bolted on an extra thermostat housing in place of the pump and then put the electric one in line with some longer radiator hose. I ran the pump with a simple on off switch in the car and in hot weather it worked like a dream. I never checked for gas mileage. A trick that a lot of drag racers use is to cut off every other fin inside the water pump. They have less drag, more power, more miles per gallon, and adequate cooling.
42 time NHRA/IHRA drag race champ
05 SRT4-12.17@117 mph on DOTs-31.0 mpg-SOLD
96 Geo Metro-3 banger-60.1 mpg-SOLD
95 BMW M3-13.41 @ 106 mph-31mpg-SOLD
77 Chevy Monza with 350/350-FOR SALE
84 Horizon-1880 lbs-29 mpg
95 Neon-43 mpg
99 Z28-10.80 @ 127 mph-27.1mpg
2011 Prius-62.1 wife's
