Originally Posted by Rishar
There's a few attach points. There are 5 under the hatch spoiler. I'll be removing the tail lights from their current location and using mount points that are behind them. I'm not sure about lower. I'll be removing the bumper at a later time (not difficult as it turns out) and looking behind it for the lower points.
I certainly would not want to do it over, you are right about that Aerohead. What I did was mostly just a way to extend the current contours of the Prius. Not quite right as you pointed out. Though I'm not sure how to line it up so it is right on. Based on how it reads "I think" it goes like this?
Which would be way off as far as a streamlined rear end with that overlay...which makes me think I'm doing it wrong.
Or this one which is 'mostly' lined up.
![](http://i62.tinypic.com/95mssz.jpg)
The upper image looks correct.
The offset in the contour makes for more work.
I did flying buttresses on my CRX to 'blend' into it
![](http://i1271.photobucket.com/albums/jj622/aerohead2/Untitled310-1.jpg)
