Thread: Yaris mods
Old 01-31-2015, 11:16 PM   #3 (permalink)
spookybathtub
Yaris - '07 Toyota Yaris hatchback
90 day: 34.85 mpg (US)
The heater core installation is complete, and it works very well. Previously, the air coming through the vents was about 15-20˚ warmer than the outside air (with AC off). This forced me to either open the windows or use the AC. This is because the Yaris uses a wimpy lever to block the heater from the air ducts.
Parts:
Four Seasons 74701 valve - $12
hose clamps - $4
This valve has a vacuum actuator, which is incompatible with the Yaris. It's very difficult to find manual valves in the right size. So I modified this with a hacksaw, leaving a manual actuator lever.
Now the vent air is almost the same temperature as outside, maybe 2-3˚ warmer. And I imagine the engine heats up faster too.
Name:	cutting heater valve.jpg
The Following 4 Users Say Thank You to spookybathtub For This Useful Post:
AndrzejM (02-24-2015), bespurcell (02-01-2015), Fat Charlie (02-25-2015), JRMichler (02-01-2015)
