Old 02-01-2015, 02:02 AM   #13 (permalink)
Rishar
What did I just do?!
Rishar's Avatar
Angry Bird - '10 Toyota Prius
90 day: 62.27 mpg (US)
Originally Posted by Vman455 View Post
Tuft test it first, otherwise you're just guessing what the airflow is doing now. I'm betting you'll find there's attached flow all the way down the back.
I had done a tuft test and you are correct, it was attached all the way down. It's why I initially went with the idea of just continuing the current contour of the Prius. (well, that and ease of build)
Originally Posted by ChazInMT View Post
And here is a trace of the above over your PhotoChops
Looks to me like if you just raised the tail lights of your shorter version by 3", you'd be very close to ideal.
Pay no mind to my diffuser area, I didn't give it much thought, but yours does seem a bit too steep, mine may be too shallow.
Aww, and here I liked my photochops...I'd never messed with that program before so I admit I got a little carried away :P
As for the diffuser area, I just moved the template overlay up so that it matched the bottom of the bumper. Seemed like an appropriate way to do it.
