Old 02-01-2015, 03:31 PM   #108 (permalink)
cowmeat
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
Full belly pan is installed!
This one took a couple of hours and cost me thirty bucks (twenty bucks for the 3x3 aluminum), but in the long run it may pay for itself. Test run was great, no melting, overheating, no smoke, cabin heat, anything like that. The coroplast is rock solid, and I used aluminum over the cat and it's not discolored after half an hour on the road.
I mounted a steel bracket for the first sheet at the back (which I had laying around) and the second sheet mounted to a bracket behind the cat, and the sheet of aluminum over the cat screwed into the front bracket already in place for the front aero panel.
The entire car has a smooth underbody now, I'll see how it fares, and what kind of affect it has on mileage.
ID:	16875   Click image for larger version
ID:	16876   Click image for larger version
ID:	16877   Click image for larger version
The Following User Says Thank You to cowmeat For This Useful Post:
mikeyjd (02-02-2015)
