Old 02-01-2015, 09:22 PM   #5 (permalink)
kv1
@cmyers What engine did you replace yours with? Did you also have a 305 in it? I will have a mechanic come look at it in the next couple days. If I were to replace it with something, what would be the best option? Will passing the smog test be harder once you replace the engine?
When you said underlying problems, what problems did you mean? All I can think which is in the van is an engine, transmission, and suspension. If I replace the engine and transmission, what else is there to worry about?
