Old 02-02-2015, 09:09 AM   #20 (permalink)
mikeyjd
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Originally Posted by ps2fixer View Post
With winter here, it is pretty hard to tell the effects of things, so I'll probably have to wait till around spring time for the tailgate test, but I suspect either way it won't effect it much.
The 10-15% drop I saw in FE with 4x4 on was with the odd ball tire up front (larger), low tires, and driving though snow. Now with all the same sized tires and tested on clear roads, I don't really see a change. The catcher with how my truck is setup, the front wheel hubs are direct locked in all the time so my front diff is always spinning. I'm sure once I get the manual lockouts swapped over that I'll see a new gain while in 2wd .
I haven't drove the truck much, but it seems FE hasn't really changed except in the distance before I'm getting warmed up numbers. I might be getting slightly better MPG while cold. I have not changed the trans / transfer case fluids yet, hoping to within the next week or so.
I won't have any SC numbers for a long time, I have a couple of other projects that need the funds before the SC. The claimed numbers were from sites where people are looking to either make their trucks fast or go though more mud, so their numbers are probably nothing special to go by, one claimed a drop 1-2mpg, and 2-3 claimed either no change or a slight increase. Depending how things go, I might get a Camry v6 manual and do an engine transplant into it with another Tacoma/4runner 3.4L . According to my research the swap is a mechanical direct bolt in, electronics are another story though.
Also question for ya mikeyjd, I see the last 3-4 tank fill ups are a steady increase in MPG, the temp hasn't done the same thing, so what are you doing different? I'll take a stab and guess you were P&G, seems my truck loves predicted stops, MPG before the coast vs MPG after up to speed is always higher after the stop for me.
I haven't been towing the trailer as much lately. One of my business ventures is buying and selling used appliances. I had been using the trailer quite a bit for a while, often totally full of scrap. Recently I've joined forces with a scrapper, in a mutually beneficial exchange. As he brings them to me and I give him several peices of scrap for his more desirable machines. That way I don't have to deal with scrap runs and can make more for my time. As an added bonues, I avoid bad roads with a full trailer and can maximize my tanks. I still have to use the trailer at times for larger deliveries (only once this last tank), but the difference in FE is substantial. With 4x4 and a fully loaded trailer and bed on snowy roads I get about 16mpg instant on flat. When empty the roads are clear and I can pulse and glide I can usually get 30+ on my trips, since I rarely drive less than 20 miles 1 way.
