Old 02-02-2015, 10:43 PM   #24 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
The 6.2L will bolt to any transmission that the small block bolts to. But I don't know if the transmission mount or driveshaft length will be correct. I'm also not sure where the shifter would come up through the floor on a van. I'm guessing the manual vans were column shift and likely only 3-speeds.
A 3.08 rear end is fine for a 6.2L without overdrive. But obviously better with overdrive.
Do some research on running used cooking oil on the 6.2L. The DB2 injection pump is pretty fragile.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
