Old 02-03-2015, 10:46 PM   #40 (permalink)
mswehx
trustyHX - '97 honda civic HX
90 day: 50.15 mpg (US)
I'm down to39mpg now I only fill with strait gas no ethanol,primary o2 changed 1 time almost 300k or so and secondary 2times, mine is under the car as I have a full stainless exh. system so not a stock exhaust. also cold air intake. The lower compression is killing the mpgs. Car still runs good though 145psi-165psi comp.
The Following User Says Thank You to mswehx For This Useful Post:
figit090 (02-07-2015)
