Old 02-04-2015, 09:59 PM   #254 (permalink)
e*clipse
Permanent Apprentice
freebeard,
They didn't have connectors or pigtails for the resolver and temperature sensor.
They did have the big orange cable, which I think he quoted at $125
I will ask about the crossbar.
Regarding the half-shaft, that may be the front half-shaft, or it may merely be a stock generic image.
The real OE ones do have teeth & splines - the teeth are for the ABS sensor. On the flange side it looks like they use a tripod joint instead of a 6 ball rzeppa joint.
I think Paul also has a VW - perhaps you can help him out with some of the VW specifics?
Thanks a bunch,
E*cipse
