Originally Posted by War_Wagon
Looking good! If you want to get rid of the rust color around the rust bubbles without actually popping them, you can try toothpaste or gritty hand cleaner on a Q-Tip. Work around the edge of the bubble carefully, and it should get rid of the rust stains. The bubbles will still be there of course but it will clean up the paint surface. Hit it with some wax after and you should be good. Clay bar will work too, but toothpaste is cheaper!
Saved in brain for future use.
