Thread: Nissan Leaf
Old 02-05-2015, 11:10 AM   #291 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
ALL the EPA testing is done by the manufacturers, on the honor system.
In warmer weather, I have greatly exceeded the EPA rating - and I am measuring it at the plug. Initially, I used a Kill-A-Watt on the factory Level 1 EVSE, and now I am using the JuiceBox Premium. And I am correcting for the known odometer inaccuracy, too.
I think you can trust the EPA Combined rating on EV's to be almost a minimum.
The volt is arguably not very impressive when the temperature creeps below 25 degrees F.
The battery heater chips away at the range quite massively.
Generally 40 degrees out I get 50 miles on a charge
Below 25 it creeps toward 31 miles (but I can usually eek 40 if its not too cold and if I can avoid erdtt)
