Old 07-22-2008, 11:38 PM   #5 (permalink)
2000mustang fan
SilverStang - '00 Ford Mustang
90 day: 22.23 mpg (US)
Originally Posted by azraelswrd View Post
Unplug it, leave it inside somewhere cool.... then plug it back in. If its still all wacky, try resetting everything:
MORE >> MORE >> MORE >> USE DEFAULTS >> YES
If all else fails, call up LL and tell them your troubles.
ok everything is still a bit confusing but its only under the today part not under current or tank. the weird values only appear under the today thing not in current or in tank but the odd thing is the scangauge thinks I filled up and I'm only slightly below 1/4Tank of a 15.7Gallon tank is this what caused the problem because it needs to be refilled at 1/4 tank or it will go beserk?
Finally got my 20% above EPA
