A quick Google search found this paper which has several charts relating to temperature affects on the discharge capacity of LiFePo4 cells.
http://ecst.ecsdl.org/content/3/36/3.full.pdf
Discharging at a high rate (eg. EVs) and low temperatures significantly decreases the amount of energy the cell will deliver. Even at room temperature the cells capacity takes a big hit compared to a cell discharging at 60 degrees C.
I wonder how much energy is used to heat the cells versus the increased capacity this gives. If the manufacturer is adding the cell heaters then total energy delivered must be higher.
