Old 02-06-2015, 05:06 PM   #1676 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by MPaulHolmes View Post
I'm so glad it arrived!
Me too!
I included some things for interfacing to the outside world. I wasn't sure how you wanted to do that part.
That's the 4 cable glands and the 4 x 6 terminal strips, right?
Also my thinking on the current sensors was, if the 3 phase lines were mated to a yet to exist end plate, it wouldn't matter that the 3 current sensors were not bolted down (they could just be around the cable)
Good idea! I'll see if I can cobble together something for that end-plate.
.. If I use 1 end plate on the inside, then the current sensors go around the cables, then another end plate on the outside, the current sensors should not rattle around. Maybe I can use some packing foam to keep the each of the current sensors centered around the cable. It may not be more accurate, but it should be more consistent. ...
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (02-07-2015)
