Old 02-06-2015, 05:52 PM   #49 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
4) You need +12v to the injection pump when the ignition is on. This turns the injection pump (and engine) on and off. There are two more wires going to the injection pump. One for fast idle and one for timing advance. They both get connected to a temperature switch. You might not need this in LA, but it will help with cold starts.
9) This is where you put fuel into the van. Most diesel nozzles are bigger.
10) You have a vacuum pump on your engine. I don't know if it's strong enough for the brakes. GM always used Hydroboost on the diesels.
12) The glow plugs are only used for about 10 seconds. Normally you'd turn the ignition on and a "glow plug" or "wait to start" light would come on. When that goes out, you can crank the engine. But the glow plug controllers tend to fail and are expensive to replace. When the controller died on my 6.2L, I used a button to replace it. So I had to push the button and count to 10 before starting. You still need a relay for the glow plugs. They will melt most switches.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
kv1 (02-13-2015)
