D15Z1 Engine Longblock - $250 Bacliff
This is 90% of a D15Z1 VTEC-E engine from a Civic VX, the engine was pulled in favor of a GSR swap years ago.
This engine has been garage stored since being pulled. No damage from the elements here.
This would make an excellent candidate for a rebuild to swap into your aging VX.
This engine will require a gasket kit, and a few small bits and bolts from your original engine.
I'm calling it 90% as the exhaust manifold is missing.
Included are the throttle body, intake manifold, fuel rail, injectors, fuel pressure regulator, oil cooler/warmer, alternator, alternator bracket, crank, pulley, pistons, head, rods, bearings, valve cover, catalytic converter, flywheel, pressure plate, friction disk, thermostat housing, oil pressure sensor, EGR, heat shield, and VTEC solenoid.
Questions can be asked and pics can be seen on my Craigslist ad at:
