Originally Posted by thingstodo
... If I use 1 end plate on the inside, then the current sensors go around the cables, then another end plate on the outside, the current sensors should not rattle around. Maybe I can use some packing foam to keep the each of the current sensors centered around the cable. It may not be more accurate, but it should be more consistent. ...
How about some plastic cable ties, should keep the sensors from sliding on the cable.
Put the cable tie through the sensor going in on one side of the cable and out on the opposite then diagonally over the top. Then another one at 90 degrees to the first so you get a crossover of the cable ties. That should keep them from moving anywhere.
