Ball Valve!! it had no throttle linkage anyway. Also, I put a tube down into the fuel that allows air to bubble through so that it can help evaporate the fuel faster depending on "throttle" position. I had it running really good today for about 10-15 minutes, but then i decided to try something else to see how it would work and it hasn't run right since.however i do have an idea why, i just need to get the stuff to see if it will work. I'll let you know how it goes!!
